New interface
Journal articles
Inversion of reflection seismograms by differential semblance analysis: algorithm structure and synthetic examples1
Abstract : Seismograms predicted from acoustic or elastic earth models depend very non-linearly on the long wavelength components of velocity. This sensitive dependence demands the use of special variational principles in waveform-based inversion algorithms. The differential semblance variational principle is well-suited to velocity inversion by gradient methods, since its objective function is smooth and convex over a large range of velocity models. An extension of the adjoint state technique yields an accurate estimate of the differential semblance gradient. Non-linear conjugate gradient iteration is quite successful in locating the global differential semblance minimum, which is near the ordinary least-squares global minimum when coherent data noise is small. Several examples, based on the 2D primaries-only acoustic model, illustrate features of the method and its performance.
Complete list of metadata
https://hal.inria.fr/hal-01111969
Contributor : Michel Kern Connect in order to contact the contributor
Submitted on : Monday, February 2, 2015 - 2:46:30 AM
Last modification on : Friday, November 18, 2022 - 9:23:03 AM
Links full text
Identifiers
Collections
Citation
William W. Symes, Michel Kern. Inversion of reflection seismograms by differential semblance analysis: algorithm structure and synthetic examples1. Geophysical Prospecting, 1994, 42 (6), pp.49. ⟨10.1111/j.1365-2478.1994.tb00231.x⟩. ⟨hal-01111969⟩
Share
Metrics
Record views
154
