Inversion of reflection seismograms by differential semblance analysis: algorithm structure and synthetic examples1 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geophysical Prospecting Année : 1994
Seismograms predicted from acoustic or elastic earth models depend very non-linearly on the long wavelength components of velocity. This sensitive dependence demands the use of special variational principles in waveform-based inversion algorithms. The differential semblance variational principle is well-suited to velocity inversion by gradient methods, since its objective function is smooth and convex over a large range of velocity models. An extension of the adjoint state technique yields an accurate estimate of the differential semblance gradient. Non-linear conjugate gradient iteration is quite successful in locating the global differential semblance minimum, which is near the ordinary least-squares global minimum when coherent data noise is small. Several examples, based on the 2D primaries-only acoustic model, illustrate features of the method and its performance.
hal-01111969 , version 1 (02-02-2015)
William W. Symes, Michel Kern. Inversion of reflection seismograms by differential semblance analysis: algorithm structure and synthetic examples1. Geophysical Prospecting, 1994, 42 (6), pp.49. ⟨10.1111/j.1365-2478.1994.tb00231.x⟩. ⟨hal-01111969⟩
168 Consultations
0 Téléchargements
