Ventcell conditions with mixed formulations for flow in porous media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we study the Optimized Schwarz method with Ventcell conditions in the context of mixed formulations, which is not as straightforward as in the case of primal formulations and we have to introduce Lagrange multipliers on the interfaces to handle tangential derivatives involved in those conditions. Two dimensional numerical results for heterogeneous problems will be presented to compare the performance of the Ventcell transmission conditions with that of the Robin transmission conditions.
dd22final.pdf (141.5 Ko) Télécharger le fichier
hal-01113964 , version 1 (06-02-2015)
  • HAL Id : hal-01113964 , version 1
Thi Thao Phuong Hoang, Caroline Japhet, Michel Kern, Jean E. Roberts. Ventcell conditions with mixed formulations for flow in porous media. 22th International conference on domain decomposition methods, Sep 2013, Lugano, Switzerland. ⟨hal-01113964⟩
329 Consultations
153 Téléchargements
