Automated removal of quasiperiodic noise using frequency domain statistics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Electronic Imaging Année : 2015
Michel Grediac
  • Fonction : Auteur
  • PersonId : 866100
Digital images may be impaired by periodic or quasiperiodic noise, which manifests itself by spurious long-range repetitive patterns. Most of the time, quasiperiodic noise is well localized in the Fourier domain; thus it can be attenuated by smoothing out the image spectrum with a well-designed notch filter. While existing algorithms require hand-tuned filter design or parameter setting, this paper presents an automated approach based on the expected power spectrum of a natural image. The resulting algorithm enables not only the elimination of simple periodic noise whose influence on the image spectrum is limited to a few Fourier coefficients, but also of quasiperiodic structured noise with a much more complex contribution to the spectrum. Various examples illustrate the efficiency of the proposed algorithm. A comparison with morphological component analysis, a blind source separation algorithm, is also provided. A MATLAB® implementation is available.
JEI-14340_Final proof 2.pdf (18.25 Mo) Télécharger le fichier
hal-01116309 , version 1 (13-02-2015)
Frédéric Sur, Michel Grediac. Automated removal of quasiperiodic noise using frequency domain statistics. Journal of Electronic Imaging, 2015, 24 (1), pp.013003/1-19. ⟨10.1117/1.JEI.24.1.013003⟩. ⟨hal-01116309⟩
537 Consultations
320 Téléchargements
