A fresh look at ramp metering control: ALINEA without any tedious calibration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
ALINEA is a well known ramp metering closed-loop control the aim of which is to improve highway traffic. This report shows that ALINEA may be slightly modified in order to be efficiently implemented without any need of crucial time-varying quantities, like the critical density and the free-flow speed, which are most difficult to estimate correctly online. Some convincing computer experiments, which employ real data, are displayed and discussed.
ALINEA_Feb15.pdf (741.24 Ko) Télécharger le fichier
hal-01117068 , version 1 (16-02-2015)
  • HAL Id : hal-01117068 , version 1
Cédric Join, Hassane Abouaïssa, Michel Fliess. A fresh look at ramp metering control: ALINEA without any tedious calibration. [Research Report] Ecole polytechnique, Palaiseau, France. 2015. ⟨hal-01117068⟩
666 Consultations
603 Téléchargements
