The Lighthill-Whitham- Richards traffic flow model with non-local velocity: analytical study and numerical results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
We consider an extension of the classical Lighthill-Whitham-Richards traffic flow model, in which the mean velocity is assumed to be dependent on the downstream traffic density. We generalize the results of [BlandinGoatin] to a general velocity function v, and propose a second order numerical scheme to compute approximate solutions.
RR-8685.pdf (1.11 Mo) Télécharger le fichier
hal-01118734 , version 1 (19-02-2015)
  • HAL Id : hal-01118734 , version 1
Paola Goatin, Sheila Scialanga. The Lighthill-Whitham- Richards traffic flow model with non-local velocity: analytical study and numerical results. [Research Report] RR-8685, Inria Sophia Antipolis; INRIA. 2015, pp.36. ⟨hal-01118734⟩
760 Consultations
1373 Téléchargements
