Numerical Approximations to Fractional Problems of the Calculus of Variations and Optimal Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2014
This chapter presents some numerical methods to solve problems in the fractional calculus of variations and fractional optimal control. Although there are plenty of methods available in the literature, we concentrate mainly on approximating the fractional problem either by discretizing the fractional term or expanding the fractional derivatives as a series involving integer order derivatives. The former method, as a subclass of direct methods in the theory of calculus of variations, uses finite differences, Grunwald-Letnikov definition in this case, to discretize the fractional term. Any quadrature rule for integration, regarding the desired accuracy, is then used to discretize the whole problem including constraints. The final task in this method is to solve a static optimization problem to reach approximated values of the unknown functions on some mesh points. The latter method, however, approximates fractional problems by classical ones in which only derivatives of integer order are present. Precisely, two continuous approximations for fractional derivatives by series involving ordinary derivatives are introduced. Local upper bounds for truncation errors are provided and, through some test functions, the accuracy of the approximations are justified. Then we substitute the fractional term in the original problem with these series and transform the fractional problem to an ordinary one. Hereafter, we use indirect methods of classical theory, e.g. Euler-Lagrange equations, to solve the approximated problem. The methods are mainly developed through some concrete examples which either have obvious solutions or the solution is computed using the fractional Euler-Lagrange equation.
1310.5377v2.pdf (383.76 Ko) Télécharger le fichier
hal-01122341 , version 1 (03-03-2015)
Shakoor Pooseh, Ricardo Almeida, Delfim F. M. Torres. Numerical Approximations to Fractional Problems of the Calculus of Variations and Optimal Control. Jacky Cresson. Fractional Calculus in Analysis, Dynamics and Optimal Control, Nova Science Publishers, pp.201-239, 2014, Mathematics Research Developments, 978-1-62948-635-2. ⟨hal-01122341⟩
Collections
SADCO TDS-MACS
69 Consultations
902 Téléchargements
