A Necessary Condition for Waveforms with Better PAPR than OFDM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Communications Année : 2016
This paper establishes a necessary condition that must be satisfied by the modulation waveforms of any generalized waveforms for multicarrier (GWMC) system with better peak-to-average power ratio (PAPR) than conventional orthogonal frequency division multiplexing (OFDM). GWMC systems include in particular all classical multicarrier modulation systems. As a consequence, we show that OFDM has the best PAPR performance over all GWMC systems that do not satisfy this necessary condition. We also identify an infinite family of GWMC systems with the same PAPR performance as OFDM. To illustrate our results, we present simulations of the PAPR behaviour for different GWMC systems, including some with better PAPR performance than OFDM.
TCOM_necessary_condition.pdf (1.89 Mo) Télécharger le fichier
hal-01128714 , version 1 (10-03-2015)
hal-01128714 , version 2 (25-09-2015)
hal-01128714 , version 3 (30-06-2016)
Marwa Chafii, Jacques Palicot, Rémi Gribonval, Faouzi Bader. A Necessary Condition for Waveforms with Better PAPR than OFDM. IEEE Transactions on Communications, 2016, 64 (8), pp.3395-3405. ⟨10.1109/TCOMM.2016.2584068⟩. ⟨hal-01128714v3⟩
559 Consultations
822 Téléchargements
