A Necessary Condition for Designing Waveforms with better PAPR than OFDM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
This paper analyses the behaviour of the peak-to-average power ratio (PAPR) in multi-carrier modulation (MCM) systems regarding to the modulation waveform. The study gives a necessary condition of improving the PAPR performance compared with the conventional orthogonal frequency division multiplexing (OFDM) system based on Fourier transform and rectangular filter. In addition, we show in which conditions on the waveform, OFDM is optimal in terms of PAPR performance, and we define an infinite family of optimal MCM systems for the given modulation conditions. To illustrate our results, we present simulations of the PAPR behaviour for different MCM systems.
chafii_double_column.pdf (350.05 Ko) Télécharger le fichier
hal-01128714 , version 1 (10-03-2015)
hal-01128714 , version 2 (25-09-2015)
hal-01128714 , version 3 (30-06-2016)
  • HAL Id : hal-01128714 , version 2
Marwa Chafii, Jacques Palicot, Rémi Gribonval. A Necessary Condition for Designing Waveforms with better PAPR than OFDM. 2015. ⟨hal-01128714v2⟩
567 Consultations
838 Téléchargements
