Is OFDM an Optimal Multi-Carrier Modulation System in Terms of PAPR Performance? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
Several Multi-Carrier Modulation systems based on different waveforms and pulse shapes are competing nowadays the conventional Orthogonal Frequency Division Multiplexing (OFDM) system based on the Fourier transform and the rectangular filter, in terms of Bit Error Rate, Spectral Efficiency, computational complexity, and other measures. In this paper, we prove analytically that, under certain constraints on the modulation scheme, conventional OFDM has an optimal Peak-to-Average Power Ratio performance.
chafii_Hal_IEEE_transactions.pdf (460.31 Ko) Télécharger le fichier
hal-01128714 , version 1 (10-03-2015)
hal-01128714 , version 2 (25-09-2015)
hal-01128714 , version 3 (30-06-2016)
  • HAL Id : hal-01128714 , version 1
Marwa Chafii, Jacques Palicot, Rémi Gribonval. Is OFDM an Optimal Multi-Carrier Modulation System in Terms of PAPR Performance?. 2015. ⟨hal-01128714v1⟩
567 Consultations
838 Téléchargements
