Estimation of Tail Risk based on Extreme Expectiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We use tail expectiles to estimate Value at Risk (VaR), Expected Shortfall (ES) and Marginal Expected Shortfall (MES), three instruments of risk protection of utmost importance in actuarial science and statistical finance. The concept of expectiles is a least squares analogue of quantiles. Both expectiles and quantiles were embedded in the more general class of M-quantiles as the minimizers of an asymmetric convex loss function. It has been proved very recently that the only M-quantiles that are coherent risk measures are the expectiles. Moreover, expectiles define the only coherent risk measure that is also elicitable. The elicitability corresponds to the existence of a natural backtesting methodology. The estimation of expectiles did not, however, receive yet any attention from the perspective of extreme values. The first estimation method that we propose enables the usage of advanced high quantile and tail-index estimators. The second method joins together the least asymmetrically weighted squares estimation with the tail restrictions of extreme-value theory. We establish the limit distributions of the proposed estimators when they are located in the range of the data or near and even beyond the maximum observed loss. A main tool is to first estimate the intermediate large expectile-based VaR, ES and MES, and then extrapolate these estimates to the very far tails. We show through a detailed simulation study the good performance of the procedures, and also present concrete applications to medical insurance data and three large US investment banks.
DGS_JRSSB_Main_file_short.pdf (4.54 Mo) Télécharger le fichier
r_code_and_data.zip (8.91 Mo) Télécharger le fichier
Format : Autre
Commentaire : data and code associated with the manuscript
hal-01142130 , version 1 (14-04-2015)
hal-01142130 , version 2 (02-06-2017)
hal-01142130 , version 3 (05-07-2017)
hal-01142130 , version 4 (17-09-2019)
hal-01142130 , version 5 (28-01-2020)
  • HAL Id : hal-01142130 , version 2
Abdelaati Daouia, Stéphane Girard, Gilles Stupfler. Estimation of Tail Risk based on Extreme Expectiles. 2017. ⟨hal-01142130v2⟩
1455 Consultations
1673 Téléchargements
