Estimation of Tail Risk based on Extreme Expectiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the Royal Statistical Society: Series B Année : 2018
We use tail expectiles to estimate alternative measures to the Value at Risk (VaR) and Marginal Expected Shortfall (MES), two instruments of risk protection of utmost importance in actuarial science and statistical finance. The concept of expectiles is a least squares analogue of quantiles. Both are M-quantiles as the minimizers of an asymmetric convex loss function, but expectiles are the only M-quantiles that are coherent risk measures. Moreover, expectiles define the only coherent risk measure that is also elicitable. The estimation of expectiles has not, however, received any attention yet from the perspective of extreme values. Two estimation methods are proposed here, either making use of quantiles or relying directly on least asymmetrically weighted squares. A main tool is to first estimate large values of expectile-based VaR and MES located within the range of the data, and then to extrapolate the obtained estimates to the very far tails. We establish the limit distributions of both of the resulting intermediate and extreme estimators. We show via a detailed simulation study the good performance of the procedures, and present concrete applications to medical insurance data and three large US investment banks.
DGS_JRSSB_Main_file_final_revision.pdf (3.6 Mo) Télécharger le fichier
DGS_JRSSB_Supplementary_file_final_revision.pdf (8.96 Mo) Télécharger le fichier
hal-01142130 , version 1 (14-04-2015)
hal-01142130 , version 2 (02-06-2017)
hal-01142130 , version 3 (05-07-2017)
hal-01142130 , version 4 (17-09-2019)
hal-01142130 , version 5 (28-01-2020)
Abdelaati Daouia, Stéphane Girard, Gilles Stupfler. Estimation of Tail Risk based on Extreme Expectiles. Journal of the Royal Statistical Society: Series B, 2018, 80 (2), pp.263-292. ⟨10.1111/rssb.12254⟩. ⟨hal-01142130v4⟩
1452 Consultations
1665 Téléchargements
