Weighted Homogeneity for Time-Delay Systems: Finite-Time and Independent of Delay Stability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2016
Global delay independent stability is analyzed for nonlinear time-delay systems by applying homogeneity theory. It is shown that finite-time stability can be encountered in this class of systems under uniformity of the convergence time with respect to delay. Some additional tools for stability analysis of time-delay systems using homogeneity are also presented: in particular, it is shown that if a time-delay system is homogeneous with nonzero degree and it is globally asymptotically stable for some delay, then this property is preserved for any delay value, which is known as the independent of delay (IOD) stability.
FTS_time_delay_6p.pdf (334.04 Ko) Télécharger le fichier
hal-01145321 , version 1 (27-04-2015)
hal-01145321 , version 2 (15-05-2015)
Denis Efimov, Andrey Polyakov, Wilfrid Perruquetti, Jean-Pierre Richard. Weighted Homogeneity for Time-Delay Systems: Finite-Time and Independent of Delay Stability. IEEE Transactions on Automatic Control, 2016, 61, pp.210-215. ⟨10.1109/TAC.2015.2427671⟩. ⟨hal-01145321v2⟩
301 Consultations
587 Téléchargements
