Study of a pseudo-stationary state for a corrosion model: existence and numerical approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Real World Applications Année : 2016
In this paper, we consider a system of partial differential equations describing the pseudo-stationary state of a dense oxide layer. We investigate the question of existence of a solution to the system and we design a numerical scheme for its approximation. Numerical experiments with real-life data shows the efficiency of the method. Then, the analysis is fulfilled on some simplified models.
DPCM.pdf (710.68 Ko) Télécharger le fichier
hal-01147621 , version 1 (30-04-2015)
Domaine public
Claire Chainais-Hillairet, Thomas Gallouët. Study of a pseudo-stationary state for a corrosion model: existence and numerical approximation. Nonlinear Analysis: Real World Applications, 2016, 31, pp.38-56. ⟨10.1016/j.nonrwa.2016.01.010⟩. ⟨hal-01147621⟩
213 Consultations
369 Téléchargements
