About dynamical system modelling: illustration in micro-biology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2014
This lecture will show the modelling approach illustrated on microbial ecosystems: - building simple dynamical models from experimental and expert knowledge, - implementing analysis and simulation methodologies to predict time evolutions and bring insights on biological phenomena, - identifying models on real data, - using models for decision making.
PresentationAlainRAPAPORT.pdf (1.4 Mo) Télécharger le fichier
hal-01154687 , version 1 (01-06-2015)
  • HAL Id : hal-01154687 , version 1
Alain Rapaport. About dynamical system modelling: illustration in micro-biology. AgreenSkills’ Research School “Predictive modelling: from data to models, 2014. ⟨hal-01154687⟩
291 Consultations
38 Téléchargements
