Distribution of postcritically finite polynomials II: Speed of convergence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
In the moduli space of degree d polynomials, we prove the equidistribution of postcritically finite polynomials toward the bifurcation measure. More precisely, using complex analytic arguments and pluripotential theory, we prove the exponential speed of convergence for C 2-observables. This improves results obtained with arithmetic methods by Favre and Rivera-Letellier in the unicritical family and Favre and the first author in the space of degree d polynomials. We deduce from that the equidistribution of hyperbolic parameters with (d − 1) distinct attracting cycles of given multipliers toward the bifurcation measure with exponential speed for C 1-observables. As an application, we prove the equidistribution (up to an explicit extraction) of parameters with (d − 1) distinct cycles with prescribed multiplier toward the bifurcation measure for any (d − 1) multipliers outside a pluripolar set.
DistribGab-v3.pdf (435.65 Ko) Télécharger le fichier
hal-01155711 , version 1 (27-05-2015)
hal-01155711 , version 2 (28-03-2016)
hal-01155711 , version 3 (01-12-2016)
Thomas Gauthier, Gabriel Vigny. Distribution of postcritically finite polynomials II: Speed of convergence. 2016. ⟨hal-01155711v3⟩
68 Consultations
115 Téléchargements
