Design of Interval Observers for Estimation and Stabilization of Discrete-Time LPV Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Mathematical Control and Information Année : 2015
This work is devoted to interval observers design for discrete-time Linear Parameter-Varying (LPV) systems under the assumption that the vector of scheduling parameters is not available for measurements. Two problems are considered: a pure estimation problem and an output stabilizing feedback design problem where the stability conditions are expressed in terms of Linear Matrix Inequalities (LMIs). The efficiency of the proposed approach is demonstrated through computer simulations.
ERPZ_IMA14.pdf (842.69 Ko) Télécharger le fichier
hal-01162680 , version 1 (11-06-2015)
Denis Efimov, Tarek Raissi, Wilfrid Perruquetti, Ali Zolghadri. Design of Interval Observers for Estimation and Stabilization of Discrete-Time LPV Systems. IMA Journal of Mathematical Control and Information, 2015, pp.1--16. ⟨10.1093/imamci/dnv023⟩. ⟨hal-01162680⟩
667 Consultations
655 Téléchargements
