On noise prediction in maps obtained with global DIC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Benoît Blaysat
  • Fonction : Auteur
Michel Grediac
  • Fonction : Auteur
  • PersonId : 866100
A predictive formula giving the measurement resolution in displacement maps obtained using Digital Image Correlation was proposed some years ago in the literature. The objective of this paper is to revisit this formula and to propose a more general one which takes into account the influence of subpixel interpolation for the displacement. Moreover, a noiseless DIC tangent operator is defined to also minimize noise propagation from images to displacement maps. Simulated data enable us to assess the improvement brought about by this approach. The experimental validation is then carried out by assessing the noise in displacement maps deduced from a stack of images corrupted by noise. It is shown that specific image pre-processing tools are required to correctly predict the displacement resolution. This image pre-processing step is necessary to correctly account for the fact that noise in images is signal-dependent, and to get rid of parasitic micro-movements between camera and specimen that were experimentally observed and which corrupt noise estimation. Obtained results are analyzed and discussed.
blaysat15noise.pdf (403.08 Ko) Télécharger le fichier
hal-01163331 , version 1 (19-11-2015)
Benoît Blaysat, Michel Grediac, Frédéric Sur. On noise prediction in maps obtained with global DIC. SEM Annual Conference & Exposition on Experimental and Applied Mechanics - 2015, SEM, Jun 2015, Costa Mesa, CA, United States. pp.211-216, ⟨10.1007/978-3-319-22446-6_27⟩. ⟨hal-01163331⟩
560 Consultations
200 Téléchargements
