Exponential trend to equilibrium for the inelastic Boltzmann equation driven by a particle bath - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We consider the spatially homogeneous Boltzmann equation for inelastic hard spheres (with constant restitution coefficient $\alpha \in (0,1)$) under the thermalization induced by a host medium with a fixed Maxwellian distribution. We prove that the solution to the associated initial-value problem converges exponentially fast towards the unique equilibrium solution. The proof combines a careful spectral analysis of the linearised semigroup as well as entropy estimates. The trend towards equilibrium holds in the weakly inelastic regime in which $\alpha$ is close to $1$, and the rate of convergence is explicit and depends solely on the spectral gap of the \emph{elastic} linearised collision operator.
JAC-BL-15-submitted-2.pdf (309.22 Ko) Télécharger le fichier
hal-01170615 , version 1 (01-07-2015)
hal-01170615 , version 2 (16-07-2015)
José Alfredo Cañizo, Bertrand Lods. Exponential trend to equilibrium for the inelastic Boltzmann equation driven by a particle bath. 2015. ⟨hal-01170615v2⟩
Collections
TDS-MACS
373 Consultations
191 Téléchargements
