Global On-line Optimization for Charging Station Allocation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The goal of the Mobility2.0 project was to provide full electric vehicles users with a set of tools that reduce range anxiety and favor a partial modal shift towards public transportation. As part of this work, we have designed a so-called global optimization criterion for selecting charging stations where change of mode can occur. The idea is to minimize the mean quadratic travel time of all users, in a way that can be used for on-line allocation with good performance. We show through simulation that this leads to a sizable improvement with respect to a "greedy" station selection.
mjp_itsc2015_final.pdf (217.04 Ko) Télécharger le fichier
hal-01171751 , version 1 (08-07-2015)
Jean-Marc Lasgouttes. Global On-line Optimization for Charging Station Allocation. Intelligent Transportation Systems Conference, ITSC 2015, Sep 2015, Las Palmas de Gran Canaria, Spain. pp.1890 - 1895, ⟨10.1109/ITSC.2015.306⟩. ⟨hal-01171751⟩
92 Consultations
178 Téléchargements
