Sequential State Estimation for Electrophysiology Models with Front Level-Set Data Using Topological Gradient Derivations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new sequential estimation method for making an electrophysiology model patient-specific, with data in the form of level sets of the electrical potential. Our method incorporates a novel correction term based on topological gradients, in order to track solutions of complex patterns. Our assessments demonstrate the effectiveness of this approach, including in a realistic case of atrial fibrillation.
ElectrophysioObserver-v1.pdf (2.33 Mo) Télécharger le fichier
hal-01174916 , version 1 (10-07-2015)
Annabelle Collin, Dominique Chapelle, Philippe Moireau. Sequential State Estimation for Electrophysiology Models with Front Level-Set Data Using Topological Gradient Derivations. Functional Imaging and Modeling of the Heart 2015, Jun 2015, Maastricht, Netherlands. pp.402-411, ⟨10.1007/978-3-319-20309-6_46⟩. ⟨hal-01174916⟩
737 Consultations
231 Téléchargements
