Canonical forms for free κ-semigroups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2014
The implicit signature κ consists of the multiplication and the (ω-1)-power. We describe a procedure to transform each κ-term over a finite alphabet A into a certain canonical form and show that different canonical forms have different interpretations over some finite semigroup. The procedure of construction of the canonical forms, which is inspired in McCammond\textquoterights normal form algorithm for ω-terms interpreted over the pseudovariety A of all finite aperiodic semigroups, consists in applying elementary changes determined by an elementary set Σ of pseudoidentities. As an application, we deduce that the variety of κ-semigroups generated by the pseudovariety S of all finite semigroups is defined by the set Σ and that the free κ-semigroup generated by the alphabet A in that variety has decidable word problem. Furthermore, we show that each ω-term has a unique ω-term in canonical form with the same value over A. In particular, the canonical forms provide new, simpler, representatives for ω-terms interpreted over that pseudovariety.
dmtcs-16-1-10.pdf (4 Ko) Télécharger le fichier
hal-01179213 , version 1 (22-07-2015)
José Carlos Costa. Canonical forms for free κ-semigroups. Discrete Mathematics and Theoretical Computer Science, 2014, Vol. 16 no. 1 (1), pp.159--178. ⟨10.46298/dmtcs.1247⟩. ⟨hal-01179213⟩
Collections
TDS-MACS
34 Consultations
1404 Téléchargements
