Computing the number of h-edge spanning forests in complete bipartite graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2014
Let fm,n,h be the number of spanning forests with h edges in the complete bipartite graph Km,n. Kirchhoff\textquoterights Matrix Tree Theorem implies fm,n,m+n-1=mn-1 nm-1 when m ≥1 and n ≥1, since fm,n,m+n-1 is the number of spanning trees in Km,n. In this paper, we give an algorithm for computing fm,n,h for general m,n,h. We implement this algorithm and use it to compute all non-zero fm,n,h when m ≤50 and n ≤50 in under 2 days.
dmtcs-16-1-19.pdf (4 Ko) Télécharger le fichier
hal-01179216 , version 1 (22-07-2015)
Rebecca J Stones. Computing the number of h-edge spanning forests in complete bipartite graphs. Discrete Mathematics and Theoretical Computer Science, 2014, Vol. 16 no. 1 (1), pp.313--326. ⟨10.46298/dmtcs.1248⟩. ⟨hal-01179216⟩
Collections
TDS-MACS
88 Consultations
1623 Téléchargements
