A New Framework for Privacy-Preserving Aggregation of Time-Series Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
Aggregator-oblivious encryption is a useful notion put forward by Shi et al. in 2011 that allows an untrusted aggregator to periodically compute an aggregate value over encrypted data contributed by a set of users. Such encryption schemes find numerous applications, in particular in the context of privacy-preserving smart metering. This paper presents a general framework for constructing privacy-preserving aggregator-oblivious encryption schemes using a variant of Cramer-Shoup's paradigm of smooth projective hashing. This abstraction leads to new schemes based on a variety of complexity assumptions. It also improves upon existing constructions, providing schemes with shorter ciphertexts and better encryption times.
aggreg-tight-SPHF.pdf (680.1 Ko) Télécharger le fichier
hal-01181321 , version 1 (31-07-2015)
hal-01181321 , version 2 (19-11-2015)
hal-01181321 , version 3 (04-05-2016)
  • HAL Id : hal-01181321 , version 1
Fabrice Benhamouda, Marc Joye, Benoit Libert. A New Framework for Privacy-Preserving Aggregation of Time-Series Data. 2015. ⟨hal-01181321v1⟩
8249 Consultations
1083 Téléchargements
