A New Framework for Privacy-Preserving Aggregation of Time-Series Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Information and System Security Année : 2016
Aggregator-oblivious encryption is a useful notion put forward by Shi et al. in 2011 that allows an untrusted aggregator to periodically compute an aggregate value over encrypted data contributed by a set of users. Such encryption schemes find numerous applications, in particular in the context of privacy-preserving smart metering. This paper presents a general framework for constructing privacy-preserving aggregator-oblivious encryption schemes using a variant of Cramer-Shoup's paradigm of smooth projective hashing. This abstraction leads to new schemes based on a variety of complexity assumptions. It also improves upon existing constructions, providing schemes with shorter ciphertexts and better encryption times.
aggreg-tight-SPHF.pdf (721.5 Ko) Télécharger le fichier
hal-01181321 , version 1 (31-07-2015)
hal-01181321 , version 2 (19-11-2015)
hal-01181321 , version 3 (04-05-2016)
Copyright (Tous droits réservés)
Fabrice Benhamouda, Marc Joye, Benoît Libert. A New Framework for Privacy-Preserving Aggregation of Time-Series Data. ACM Transactions on Information and System Security, 2016, 18 (3), pp.21. ⟨10.1145/2873069⟩. ⟨hal-01181321v2⟩
8249 Consultations
1083 Téléchargements
