Compact Brownian surfaces I. Brownian disks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Probability Theory and Related Fields Année : 2017
We show that, under certain natural assumptions, large random plane bipartite maps with a boundary converge after rescaling to a one-parameter family (BD_L, 0 < L < infinity) of random metric spaces homeomorphic to the closed unit disk of R^2, the space BD_L being called the Brownian disk of perimeter L and unit area. These results can be seen as an extension of the convergence of uniform plane quadrangulations to the Brownian map, which intuitively corresponds to the limit case where L = 0. Similar results are obtained for maps following a Boltzmann distribution, in which the perimeter is fixed but the area is random.
br_disk.pdf (838.62 Ko) Télécharger le fichier
hal-01182224 , version 1 (30-07-2015)
hal-01182224 , version 2 (20-10-2015)
hal-01182224 , version 3 (12-02-2016)
Jérémie Bettinelli, Gregory Miermont. Compact Brownian surfaces I. Brownian disks. Probability Theory and Related Fields, 2017, 167 (3-4), pp.555--614. ⟨10.1007/s00440-016-0752-y⟩. ⟨hal-01182224v3⟩
272 Consultations
110 Téléchargements
