Dirichlet uniformly well-approximated numbers
Fix an irrational number $\theta$. For a real number $\tau >0$, consider the numbers $y$ satisfying that for all large number $Q$, there exists an integer $1\leq n\leq Q$, such that $\|n\theta-y\|
0$, the Haussdorff dimension of the set of these numbers is obtained and is shown to depend on the Diophantine property of $\theta$. It is also proved that with respect to $\tau$, the only possible discontinuous point of the Hausdorff dimension is $\tau=1$.
