Characterization of Lattices Induced by (extended) Chip Firing Games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2001
The Chip Firing Game (CFG) is a discrete dynamical model used in physics, computer science and economics. It is known that the set of configurationsreachable from an initial configuration (this set is called the \textitconfiguration space) can be ordered as a lattice. We first present a structural result about this model, which allows us to introduce some useful tools for describing those lattices. Then we establish that the class of lattices that are the configuration space of a CFG is strictly between the class of distributive lattices and the class of upper locally distributive (or ULD) lattices. Finally we propose an extension of the model, the \textitcoloured Chip Firing Game, which generates exactly the class of ULD lattices.
dmAA0117.pdf (152.86 Ko) Télécharger le fichier
hal-01182957 , version 1 (06-08-2015)
Clémence Magnien, Ha Duong Phan, Laurent Vuillon. Characterization of Lattices Induced by (extended) Chip Firing Games. Discrete Models: Combinatorics, Computation, and Geometry, DM-CCG 2001, 2001, Paris, France. pp.229-244, ⟨10.46298/dmtcs.2277⟩. ⟨hal-01182957⟩
234 Consultations
714 Téléchargements
