Megamaps: Construction and Examples - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2001
We consider the usual model of hypermaps or, equivalently, bipartite maps, represented by pairs of permutations that act transitively on a set of edges E. The specific feature of our construction is the fact that the elements of E are themselves (or are labelled by) rather complicated combinatorial objects, namely, the 4-constellations, while the permutations defining the hypermap originate from an action of the Hurwitz braid group on these 4-constellations.The motivation for the whole construction is the combinatorial representation of the parameter space of the ramified coverings of the Riemann sphere having four ramification points.
dmAA0124.pdf (136.79 Ko) Télécharger le fichier
hal-01182964 , version 1 (06-08-2015)
Alexander Zvonkin. Megamaps: Construction and Examples. Discrete Models: Combinatorics, Computation, and Geometry, DM-CCG 2001, 2001, Paris, France. pp.329-340, ⟨10.46298/dmtcs.2284⟩. ⟨hal-01182964⟩
Collections
CNRS TDS-MACS
115 Consultations
735 Téléchargements
