Tilings of a Domain on a Hexagon Mesh with Balanced 3-Tiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2001
In this article, we study the question of tilings on a hexagon mesh with balanced 3-tiles. This problem has been studied by Conway and Lagarias in [CL90], by studying the tiling groups, in fact a group containing the tiling-groups, and their Cayley graphs. We will use two different approaches. The first one is based on matchings in bipartite graphs, which in this case are in correspondance with tilings of domains by lozenges, and thus can be efficiently studied, using Thurston's algorithm (see [Thu90]). The second one is based on a color and balancing approach of Thurston's algorithm, exposed in [Fou96].
dmAA0121.pdf (114.34 Ko) Télécharger le fichier
hal-01182967 , version 1 (06-08-2015)
Gilles Radenne. Tilings of a Domain on a Hexagon Mesh with Balanced 3-Tiles. Discrete Models: Combinatorics, Computation, and Geometry, DM-CCG 2001, 2001, Paris, France. pp.287-300, ⟨10.46298/dmtcs.2287⟩. ⟨hal-01182967⟩
76 Consultations
653 Téléchargements
