And/or tree probabilities of Boolean functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
We consider two probability distributions on Boolean functions defined in terms of their representations by $\texttt{and/or}$ trees (or formulas). The relationships between them, and connections with the complexity of the function, are studied. New and improved bounds on these probabilities are given for a wide class of functions, with special attention being paid to the constant function $\textit{True}$ and read-once functions in a fixed number of variables.
dmAD0113.pdf (112.61 Ko) Télécharger le fichier
hal-01184027 , version 1 (12-08-2015)
Danièle Gardy, Alan Woods. And/or tree probabilities of Boolean functions. 2005 International Conference on Analysis of Algorithms, 2005, Barcelona, Spain. pp.139-146, ⟨10.46298/dmtcs.3355⟩. ⟨hal-01184027⟩
Collections
CNRS UVSQ TDS-MACS
77 Consultations
706 Téléchargements
