Profiles of random trees: plane-oriented recursive trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
We summarize several limit results for the profile of random plane-oriented recursive trees. These include the limit distribution of the normalized profile, asymptotic bimodality of the variance, asymptotic approximations of the expected width and the correlation coefficients of two level sizes. We also unveil an unexpected connection between the profile of plane-oriented recursive trees (with logarithmic height) and that of random binary trees (with height proportional to the square root of tree size).
dmAD0119.pdf (194.43 Ko) Télécharger le fichier
hal-01184033 , version 1 (12-08-2015)
Hsien-Kuei Hwang. Profiles of random trees: plane-oriented recursive trees. 2005 International Conference on Analysis of Algorithms, 2005, Barcelona, Spain. pp.193-200, ⟨10.46298/dmtcs.3361⟩. ⟨hal-01184033⟩
Collections
TDS-MACS
55 Consultations
613 Téléchargements
