Asymptotic analysis of a nonlinear AIMD algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
The Additive-Increase-Multiplicative Decrease (AIMD) algorithm is an effective technique for controlling competitive access to a shared resource. Let $N$ be the number of users and let $x_i(t)$ be the amount of the resource in possession of the $i$-th user. The allocations $x_i(t)$ increase linearly until the aggregate demand $\sum_i x_i(t)$ exceeds a given nominal capacity, at which point a user is selected at a random time and its allocation reduced from $x_i(t)$ to $x_i(t)/ \gamma$ , for some given parameter $\gamma >1$. In our new, generalized version of AIMD, the choice of users to have their allocations cut is determined by a selection rule whereby the probabilities of selection are proportional to $x_i^{\alpha} (t)/ \sum_j x_j^{\alpha}$, with $\alpha$ a parameter of the policy. Variations of parameters allows one to adjust fairness under AIMD (as measured for example by the variance of $x_i(t)$) as well as to provide for differentiated service. The primary contribution here is an asymptotic, large-$N$ analysis of the above nonlinear AIMD algorithm within a baseline mathematical model that leads to explicit formulas for the density function governing the allocations $x_i(t)$ in statistical equilibrium. The analysis yields explicit formulas for measures of fairness and several techniques for supplying differentiated service via AIMD.
dmAD0104.pdf (192.19 Ko) Télécharger le fichier
hal-01184037 , version 1 (12-08-2015)
Y. Baryshnikov, E. Coffman, J. Feng, P. Momčilović. Asymptotic analysis of a nonlinear AIMD algorithm. 2005 International Conference on Analysis of Algorithms, 2005, Barcelona, Spain. pp.27-38, ⟨10.46298/dmtcs.3365⟩. ⟨hal-01184037⟩
Collections
TDS-MACS
185 Consultations
535 Téléchargements
