On the Grone-Merris conjecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
Grone and Merris [GM94] conjectured that the Laplacian spectrum of a graph is majorized by its conjugate vertex degree sequence. We prove that this conjecture holds for a class of graphs including trees. We also show that this conjecture and its generalization to graphs with Dirichlet boundary conditions are equivalent.
dmAE0137.pdf (126.97 Ko) Télécharger le fichier
hal-01184351 , version 1 (14-08-2015)
Tamon Stephen. On the Grone-Merris conjecture. 2005 European Conference on Combinatorics, Graph Theory and Applications (EuroComb '05), 2005, Berlin, Germany. pp.187-192, ⟨10.46298/dmtcs.3395⟩. ⟨hal-01184351⟩
Collections
TDS-MACS
42 Consultations
635 Téléchargements
