Permutations with short monotone subsequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
We consider permutations of $1,2,...,n^2$ whose longest monotone subsequence is of length $n$ and are therefore extremal for the Erdős-Szekeres Theorem. Such permutations correspond via the Robinson-Schensted correspondence to pairs of square $n \times n$ Young tableaux. We show that all the bumping sequences are constant and therefore these permutations have a simple description in terms of the pair of square tableaux. We deduce a limit shape result for the plot of values of the typical such permutation, which in particular implies that the first value taken by such a permutation is with high probability $(1+o(1))n^2/2$.
dmAE0112.pdf (433.86 Ko) Télécharger le fichier
hal-01184378 , version 1 (14-08-2015)
Dan Romik. Permutations with short monotone subsequences. 2005 European Conference on Combinatorics, Graph Theory and Applications (EuroComb '05), 2005, Berlin, Germany. pp.57-62, ⟨10.46298/dmtcs.3421⟩. ⟨hal-01184378⟩
Collections
TDS-MACS
74 Consultations
495 Téléchargements
