Hadamard matrices of order 36 and double-even self-dual [72,36,12] codes
Before this work, at least 762 inequivalent Hadamard matrices of order 36 were known. We found 7238 Hadamard matrices of order 36 and 522 inequivalent [72,36,12] double-even self-dual codes which are obtained from all 2-(35,17,8) designs with an automorphism of order 3 and 2 fixed points and blocks.
