Hamiltonian Chains in Hypergraphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
Hamiltionian chain is a generalisation of hamiltonian cycles for hypergraphs. Among the several possible ways of generalisations this is probably the most strong one, it requires the strongest structure. Since there are many interesting questions about hamiltonian cycles in graphs, we can try to answer these questions for hypergraphs, too. In the present article we give a survey on results about such questions.
dmAE0167.pdf (121.58 Ko) Télécharger le fichier
hal-01184433 , version 1 (14-08-2015)
Gyula Y. Katona. Hamiltonian Chains in Hypergraphs. 2005 European Conference on Combinatorics, Graph Theory and Applications (EuroComb '05), 2005, Berlin, Germany. pp.345-350, ⟨10.46298/dmtcs.3444⟩. ⟨hal-01184433⟩
Collections
TDS-MACS
55 Consultations
689 Téléchargements
