Relaxed Two-Coloring of Cubic Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
We show that any graph of maximum degree at most $3$ has a two-coloring, such that one color-class is an independent set while the other color induces monochromatic components of order at most $189$. On the other hand for any constant $C$ we exhibit a $4$-regular graph, such that the deletion of any independent set leaves at least one component of order greater than $C$. Similar results are obtained for coloring graphs of given maximum degree with $k+ \ell$ colors such that $k$ parts form an independent set and $\ell$ parts span components of order bounded by a constant. A lot of interesting questions remain open.
dmAE0166.pdf (121.88 Ko) Télécharger le fichier
Origine Fichiers éditeurs autorisés sur une archive ouverte
hal-01184434 , version 1 (14-08-2015)
Robert Berke, Tibor Szabó. Relaxed Two-Coloring of Cubic Graphs. 2005 European Conference on Combinatorics, Graph Theory and Applications (EuroComb '05), 2005, Berlin, Germany. pp.341-344, ⟨10.46298/dmtcs.3445⟩. ⟨hal-01184434⟩
Collections
TDS-MACS
72 Consultations
588 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
