A Cross Entropy Algorithm for Classification with $\delta$−Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2006
A classification strategy based on $\delta$-patterns is developed via a combinatorial optimization problem related with the maximal clique generation problem on a graph. The proposed solution uses the cross entropy method and has the advantage to be particularly suitable for large datasets. This study is tailored for the particularities of the genomic data.
dmAG0132.pdf (149.29 Ko) Télécharger le fichier
hal-01184688 , version 1 (17-08-2015)
Gabriela Alexe, Gyan Bhanot, Adriana Climescu-Haulica. A Cross Entropy Algorithm for Classification with $\delta$−Patterns. Fourth Colloquium on Mathematics and Computer Science Algorithms, Trees, Combinatorics and Probabilities, Sep 2006, Nancy, France. pp.399-402, ⟨10.46298/dmtcs.3485⟩. ⟨hal-01184688⟩
172 Consultations
569 Téléchargements
