Random assignment and shortest path problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2006
We explore a similarity between the $n$ by $n$ random assignment problem and the random shortest path problem on the complete graph on $n+1$ vertices. This similarity is a consequence of the proof of the Parisi formula for the assignment problem given by C. Nair, B. Prabhakar and M. Sharma in 2003. We give direct proofs of the analogs for the shortest path problem of some results established by D. Aldous in connection with his $\zeta (2)$ limit theorem for the assignment problem.
dmAG0102.pdf (174.88 Ko) Télécharger le fichier
hal-01184708 , version 1 (17-08-2015)
Johan Wästlund. Random assignment and shortest path problems. Fourth Colloquium on Mathematics and Computer Science Algorithms, Trees, Combinatorics and Probabilities, 2006, Nancy, France. pp.31-38, ⟨10.46298/dmtcs.3504⟩. ⟨hal-01184708⟩
Collections
TDS-MACS
49 Consultations
509 Téléchargements
