Randomized Optimization: a Probabilistic Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2007
In 1999, Chan proposed an algorithm to solve a given optimization problem: express the solution as the minimum of the solutions of several subproblems and apply the classical randomized algorithm for finding the minimum of $r$ numbers. If the decision versions of the subproblems are easier to solve than the subproblems themselves, then a faster algorithm for the optimization problem may be obtained with randomization. In this paper we present a precise probabilistic analysis of Chan's technique.
dmAH0105.pdf (349.75 Ko) Télécharger le fichier
hal-01184788 , version 1 (17-08-2015)
Jean Cardinal, Stefan Langerman, Guy Louchard. Randomized Optimization: a Probabilistic Analysis. 2007 Conference on Analysis of Algorithms, AofA 07, 2007, Juan les Pins, France. pp.57-78, ⟨10.46298/dmtcs.3540⟩. ⟨hal-01184788⟩
Collections
TDS-MACS
35 Consultations
552 Téléchargements
