Minimal Factorizations of Permutations into Star Transpositions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2008
We give a compact expression for the number of factorizations of any permutation into a minimal number of transpositions of the form $(1 i)$. Our result generalizes earlier work of Pak ($\textit{Reduced decompositions of permutations in terms of star transpositions, generalized catalan numbers and k-ary trees}$, Discrete Math. $\textbf{204}$:329―335, 1999) in which substantial restrictions were placed on the permutation being factored.
Nous présentons une expression compacte pour le nombre de factorisations minimales d'une permutation arbitraire de transposition de la forme $(1 i)$. Ce résultat généralise le travail passé de Pak ($\textit{Reduced decompositions of permutations in terms of star transpositions, generalized catalan numbers and k-ary trees}$, Discrete Math. $\textbf{204}$:329―335, 1999) dans lequel des restrictions substantielles sont imposées sur la permutation étant factorisée.
dmAJ0144.pdf (211.46 Ko) Télécharger le fichier
hal-01185128 , version 1 (19-08-2015)
J. Irving, A. Rattan. Minimal Factorizations of Permutations into Star Transpositions. 20th Annual International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2008), 2008, Viña del Mar, Chile. pp.507-512, ⟨10.46298/dmtcs.3595⟩. ⟨hal-01185128⟩
Collections
TDS-MACS
36 Consultations
579 Téléchargements
