Enumeration of derangements with descents in prescribed positions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2009
We enumerate derangements with descents in prescribed positions. A generating function was given by Guo-Niu Han and Guoce Xin in 2007. We give a combinatorial proof of this result, and derive several explicit formulas. To this end, we consider fixed point $\lambda$-coloured permutations, which are easily enumerated. Several formulae regarding these numbers are given, as well as a generalisation of Euler's difference tables. We also prove that except in a trivial special case, if a permutation $\pi$ is chosen uniformly among all permutations on $n$ elements, the events that $\pi$ has descents in a set $S$ of positions, and that $\pi$ is a derangement, are positively correlated.
dmAK0132.pdf (235.91 Ko) Télécharger le fichier
hal-01185430 , version 1 (20-08-2015)
Niklas Eriksen, Ragnar Freij, Johan Wästlund. Enumeration of derangements with descents in prescribed positions. 21st International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2009), 2009, Hagenberg, Austria. pp.385-396, ⟨10.46298/dmtcs.2738⟩. ⟨hal-01185430⟩
Collections
TDS-MACS
45 Consultations
668 Téléchargements
