The fractal structure of cellular automata on abelian groups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2010
It is a well-known fact that the spacetime diagrams of some cellular automata have a fractal structure: for instance Pascal's triangle modulo $2$ generates a Sierpinski triangle. Explaining the fractal structure of the spacetime diagrams of cellular automata is a much explored topic, but virtually all of the results revolve around a special class of automata, whose main features include irreversibility, an alphabet with a ring structure and a rule respecting this structure, and a property known as being (weakly) $p$-Fermat. The class of automata that we study in this article fulfills none of these properties. Their cell structure is weaker and they are far from being $p$-Fermat, even weakly. However, they do produce fractal spacetime diagrams, and we will explain why and how. These automata emerge naturally from the field of quantum cellular automata, as they include the classical equivalent of the Clifford quantum cellular automata, which have been studied by the quantum community for several reasons. They are a basic building block of a universal model of quantum computation, and they can be used to generate highly entangled states, which are a primary resource for measurement-based models of quantum computing.
dmAL0105.pdf (724.04 Ko) Télécharger le fichier
hal-01185495 , version 1 (20-08-2015)
Johannes Gütschow, Vincent Nesme, Reinhard F. Werner. The fractal structure of cellular automata on abelian groups. Automata 2010 - 16th Intl. Workshop on CA and DCS, 2010, Nancy, France. pp.51-70, ⟨10.46298/dmtcs.2759⟩. ⟨hal-01185495⟩
Collections
TDS-MACS
140 Consultations
921 Téléchargements
