The number of Euler tours of a random $d$-in/$d$-out graph
In this paper we obtain the expectation and variance of the number of Euler tours of a random $d$-in/$d$-out directed graph, for $d \geq 2$. We use this to obtain the asymptotic distribution and prove a concentration result. We are then able to show that a very simple approach for uniform sampling or approximately counting Euler tours yields algorithms running in expected polynomial time for almost every $d$-in/$d$-out graph. We make use of the BEST theorem of de Bruijn, van Aardenne-Ehrenfest, Smith and Tutte, which shows that the number of Euler tours of a $d$-in/$d$-out graph is the product of the number of arborescences and the term $[(d-1)!]^n/n$. Therefore most of our effort is towards estimating the asymptotic distribution of the number of arborescences of a random $d$-in/$d$-out graph.
