Occupancy distributions in Markov chains via Doeblin's ergodicity coefficient - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2010
We state and prove new properties about Doeblin's ergodicity coefficient for finite Markov chains. We show that this coefficient satisfies a sub-multiplicative type inequality (analogous to the Markov-Dobrushin's ergodicity coefficient), and provide a novel but elementary proof of Doeblin's characterization of weak-ergodicity for non-homogeneous chains. Using Doeblin's coefficient, we illustrate how to approximate a homogeneous but possibly non-stationary Markov chain of duration $n$ by independent and short-lived realizations of an auxiliary chain of duration of order $\ln (n)$. This leads to approximations of occupancy distributions in homogeneous chains, which may be particularly useful when exact calculations via one-step methods or transfer matrices are impractical, and when asymptotic approximations may not be yet reliable. Our findings may find applications to pattern problems in Markovian and non-Markovian sequences that are treatable via embedding techniques.
dmAM0106.pdf (357.85 Ko) Télécharger le fichier
hal-01185587 , version 1 (20-08-2015)
Stephen Chestnut, Manuel E. Lladser. Occupancy distributions in Markov chains via Doeblin's ergodicity coefficient. 21st International Meeting on Probabilistic, Combinatorial, and Asymptotic Methods in the Analysis of Algorithms (AofA'10), 2010, Vienna, Austria. pp.79-92, ⟨10.46298/dmtcs.2789⟩. ⟨hal-01185587⟩
Collections
TDS-MACS
477 Consultations
1379 Téléchargements
