Nonrepetitive colorings of lexicographic product of graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2014
A coloring c of the vertices of a graph G is nonrepetitive if there exists no path v1v2\textellipsisv2l for which c(vi)=c(vl+i) for all 1<=i<=l. Given graphs G and H with |V(H)|=k, the lexicographic product G[H] is the graph obtained by substituting every vertex of G by a copy of H, and every edge of G by a copy of Kk,k. We prove that for a sufficiently long path P, a nonrepetitive coloring of P[Kk] needs at least 3k+⌊k/2⌋ colors. If k>2 then we need exactly 2k+1 colors to nonrepetitively color P[Ek], where Ek is the empty graph on k vertices. If we further require that every copy of Ek be rainbow-colored and the path P is sufficiently long, then the smallest number of colors needed for P[Ek] is at least 3k+1 and at most 3k+⌈k/2⌉. Finally, we define fractional nonrepetitive colorings of graphs and consider the connections between this notion and the above results.
Mots clés
dmtcs-16-2-8.pdf (288.98 Ko) Télécharger le fichier
hal-01185617 , version 1 (20-08-2015)
Balázs Keszegh, Balázs Patkós, Xuding Zhu. Nonrepetitive colorings of lexicographic product of graphs. Discrete Mathematics and Theoretical Computer Science, 2014, Vol. 16 no. 2 (2), pp.97--110. ⟨10.46298/dmtcs.2077⟩. ⟨hal-01185617⟩
Collections
TDS-MACS
54 Consultations
825 Téléchargements
