Mixed Statistics on $01$-Fillings of Moon Polyominoes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2010
We establish a stronger symmetry between the numbers of northeast and southeast chains in the context of $01$-fillings of moon polyominoes. Let $\mathcal{M}$ be a moon polyomino. Consider all the $01$-fillings of $\mathcal{M}$ in which every row has at most one $1$. We introduce four mixed statistics with respect to a bipartition of rows or columns of $\mathcal{M}$. More precisely, let $S$ be a subset of rows of $\mathcal{M}$. For any filling $M$, the top-mixed (resp. bottom-mixed) statistic $\alpha (S; M)$ (resp. $\beta (S; M)$) is the sum of the number of northeast chains whose top (resp. bottom) cell is in $S$, together with the number of southeast chains whose top (resp. bottom) cell is in the complement of $S$. Similarly, we define the left-mixed and right-mixed statistics $\gamma (T; M)$ and $\delta (T; M)$, where $T$ is a subset of the columns. Let $\lambda (A; M)$ be any of these four statistics $\alpha (S; M)$, $\beta (S; M)$, $\gamma (T; M)$ and $\delta (T; M)$. We show that the joint distribution of the pair $(\lambda (A; M), \lambda (M/A; M))$ is symmetric and independent of the subsets $S, T$. In particular, the pair of statistics $(\lambda (A;M), \lambda (M/A; M))$ is equidistributed with $(\mathrm{se}(M), \mathrm{ne}(M))$, where $\mathrm{se}(M)$ and $\mathrm{ne}(M)$ are the numbers of southeast chains and northeast chains of $M$, respectively.
Nous établissons une symétrie plus forte entre les nombres de chaînes nord-est et sud-est dans le cadre des remplissages $01$ des polyominos lune. Soit $\mathcal{M}$ un polyomino lune. Considérez tous les remplissages $01$ de $\mathcal{M}$ dans lesquels chaque rangée contient au plus un $1$. Nous présentons quatre statistiques mixtes sur les bipartitions des rangées et des colonnes de $\mathcal{M}$. Plus précisément, soit $S$ un sous-ensemble de rangées de $\mathcal{M}$. Pour tout remplissage $M$, la statistique mixte du dessus (resp. du dessous) $\alpha (S; M)$ (resp. $\beta (S; M)$) est la somme du nombre de chaînes nord-est dont le dessus (resp. le dessous) est dans $S$, et du nombre de chaînes sud-est dont la cellule supérieure (resp. inférieure) est dans le complément de $S$. De même, nous définissons les statistiques mixtes à gauche et à droite $\gamma (T; M)$ et $\delta (T; M)$, où $T$ est un sous-ensemble des colonnes. Soit $\lambda (A; M)$ une des quatre statistiques$\alpha (S; M)$, $\beta (S; M)$, $\gamma (T; M)$ et $\delta (T; M)$. Nous montrons que la distribution commune des paires $(\lambda (A; M), \lambda (M/A; M))$ est symétrique et indépendante des sous-ensembles $S, T$. En particulier, la paire de statistiques $(\lambda (A;M), \lambda (M/A; M))$ est équidistribuée avec $(\mathrm{se}(M), \mathrm{ne}(M))$, où $\mathrm{se}(M)$ et $\mathrm{ne}(M)$ sont les nombres de chaînes sud-est et nord-est de $M$ respectivement.
dmAN0142.pdf (368.6 Ko) Télécharger le fichier
hal-01186273 , version 1 (24-08-2015)
William Y. C. Chen, Andrew Y. Z. Wang, Catherine H. Yan, Alina F. Y. Zhao. Mixed Statistics on $01$-Fillings of Moon Polyominoes. 22nd International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2010), 2010, San Francisco, United States. pp.613-624, ⟨10.46298/dmtcs.2845⟩. ⟨hal-01186273⟩
Collections
TDS-MACS
73 Consultations
529 Téléchargements
