On the rate of convergence and error bounds for LSTD(λ) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider LSTD(λ), the least-squares temporal-difference algorithm with eligibility traces algorithm proposed by Boyan (2002). It computes a linear approximation of the value function of a fixed policy in a large Markov Decision Process. Under a β-mixing assumption , we derive, for any value of λ ∈ (0, 1), a high-probability bound on the rate of convergence of this algorithm to its limit. We deduce a high-probability bound on the error of this algorithm, that extends (and slightly improves) that derived by Lazaric et al. (2012) in the specific case where λ = 0. In the context of temporal-difference algorithms with value function approximation, this analysis is to our knowledge the first to provide insight on the choice of the eligibility-trace parameter λ with respect to the approximation quality of the space and the number of samples.
lstd.pdf (283.5 Ko) Télécharger le fichier
hal-01186667 , version 1 (25-08-2015)
  • HAL Id : hal-01186667 , version 1
Manel Tagorti, Bruno Scherrer. On the rate of convergence and error bounds for LSTD(λ). ICML 2015, Jul 2015, Lille, France. ⟨hal-01186667⟩
168 Consultations
110 Téléchargements
