Moments and Legendre-Fourier Series for Measures Supported on Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Symmetry, Integrability and Geometry : Methods and Applications Année : 2015
Some important problems (e.g., in optimal transport and optimal control) have a relaxed (or weak) formulation in a space of appropriate measures which is much easier to solve. However, an optimal solution $\mu$ of the latter solves the former if and only if the measure $\mu$ is supported on a ''trajectory'' $\{(t,x(t))\colon t\in [0,T]\}$ for some measurable function $x(t)$. We provide necessary and sufficient conditions on moments $(\gamma_{ij})$ of a measure $d\mu(x,t)$ on $[0,1]^2$ to ensure that $\mu$ is supported on a trajectory $\{(t,x(t))\colon t\in [0,1]\}$. Those conditions are stated in terms of Legendre-Fourier coefficients ${\mathbf f}_j=({\mathbf f}_j(i))$ associated with some functions $f_j\colon [0,1]\to {\mathbb R}$, $j=1,\ldots$, where each ${\mathbf f}_j$ is obtained from the moments $\gamma_{ji}$, $i=0,1,\ldots$, of $\mu$.
sigma15-077.pdf (347.99 Ko) Télécharger le fichier
hal-01187750 , version 1 (27-08-2015)
hal-01187750 , version 2 (29-09-2015)
Jean-Bernard Lasserre. Moments and Legendre-Fourier Series for Measures Supported on Curves. Symmetry, Integrability and Geometry : Methods and Applications, 2015, Special Issue on Orthogonal Polynomials, Special Functions and Applications, 11 (077), 10 p. ⟨10.3842/SIGMA.2015.077⟩. ⟨hal-01187750v2⟩
234 Consultations
365 Téléchargements
